brake light illuminated (barely) all the time
PNW
ok, so beyond the shaky 80 syndrome that i've been having. I recently noticed on my way to class at 06:00 that my brake light is dimly lit even with the parking brake off. I know that in most situations that the brake light stays on when low on brake fluid. mine is actually above full, would this cause my problem? I didnt think it would. I played around with the brake pedal as well as the parking brake lever. The only change was that it became more brilliant when the parking brake was actually engaged than when it had no tension on it.
any ideas? this one has got me as confused as the shaking syndrome.
The reservoir cap may have gone bad. This happened to me a while back, had to replace the cap... Not too expensive, IIRC.
My cruise control still doesn't work. :frown:
We can fix that you know...
Curtis
Yeah yeah yeah, I already know what's wrong with it. But I just don't care anymore. :flipoff2:
Onto the poor man's cruise control....OEM hand throttle.
bad cap huh? interesting. what in the cap causes this? is it due to the level indicator?
lka1988
don't worry, mine doesn't either. I'm trying to get the important things figured out before I move on to the Fufu stuff.
:cheers:
Maybe not related, but I wonder this light also comes on to indicate lacks of vaccum to operate the asisted brakes ( brake booster )
the verdict is in. I unplugged the brake cap. it turned off. I need to get a new one.
thanks,
ryan
I had the same issue with the brake light fading in and out, sorta glowing but not fully on. After a go-around with the dealer up here (armed with educated intelligence from MUD), I ended up driving to the US and purchasing one for myself. Due to my inability to even earn a banana peel, I convinced the parts guy to install it as well...:D.
Problem solved... I LOVE MUD!!!:cheers:
Ditto on some other posts; the sending unit on top of
the brake fluid reservoir is probably bad, but be sure
that the braking performance of the vehicle is good;
ie: that you are not losing any pedal pressure or braking
force.
g
pedal pressure is still good, no fading at all. I'm going to bleed the whole system once I install my new rotors once they arrive
Always a good idea for anyone at anytime.
However, this would be related to his symptoms (he stated that the brake fluid level is not low) how exactly?
Curtis
My brake light glowed just a tad for sometime; I eventually replaced the reservior cap/sending unit. However, not too long after that, maybe a couple of months tops, in a panic stop the pedal went to the floor, causing me to rear end someone slightly.
At first, I thought it was just my (slow) reaction time causing the accident, but not more than three days later, someone pulled
in front of me again to turn, again causing me to mash on the pedal,
same thing; pedal to the floor with little braking; this time I was
able to steer out of trouble.
Took it to the best brake guy in my area; bad master cylinder.
g
wow, I never would have guessed a bad master cylinder due to an illuminating brake light. My brake pedal feels the same at it ever has. I am going to go through the whole brake system once my other brake parts arrive so I can do it all at once and concentrate on the whole thing instead of just a few different areas.
If I find anything I will post it up for sure. I'm going to RR all my brake lines w/ SS extended lines. I'm going from frame to axle and axle to caliper. I'll end up draining a bunch of old fluid out during the swap. Them I'll bleed the system from the corners, and the LSPV. When I bled from my LSPV on my last cruiser, it changed the brake pedal pressure completely. You'd be surprised at the amount of gunk that'll come out of there. I'd bled the brakes from each corner until I crawled underneath it one day and saw the bleeder nipple on it. I was curious to know is there were deposits in there. I was right. :idea:
The reason why my fluid level is high right now, is because when I purchased the vehicle in May, it was a just a little low. So i added some. I recently put new pads on it and since the pistons were compressed more, the excess went back into the reservoir. :cheers:
Got that problem with mine, I removed the cap, played with it a little, and replaced it. It's been about two months and the light still out.
A friend told me he thought it might be the switch that tells you your e-brake is on. I found this, topped off my brake fluid, and VOILA! No light! Thanks, IH8MUD!
rob
