Check Engine Light and Sputtering
The 100 has no plug wires but the coil packs have been known to fail and set a CEL with rough running. Usually a single coil pack is bad and the CEL code will help trouble shoot the problem.
Plugs are due to be changed at 120k so maybe plan on doing them as well. CruiserDan or SinCity can hook you up with OEM plugs and the Denso iridium have been used with success.
Check engine light and rough idle and drive
Spark plug #5?
