Do I need a Speedi Sleeve?
Southwest, MO
Ok, I got around to pulling the park brake off again, due to the fact I changed out the pads and things a month ago and still had a leak. I noticed that the drum is grooved where it slips onto the splines. Is this where SOR is talking about if you can catch your finger nail you need to sleeve it?
If it leaks and you can catch your fingernail, a speedie sleeve should help. Unless the problem is worn bearing wobble.
Put in a Speedi Sleeve and do the double seal and be done with it.
