Flares removed, lined, replaced.
Sandy Eggo
Yep, another lined flare thread. In addition to the flares, I did the backs of the mirrors, rear ‘bumperettes’, and the side ‘trim’ areas. I’ve used Hurculiner in the past for the tub of my 40 and the cargo area of the Suburban. After reading 95eighty’s thread Bed Liner in Place of Factory Flares... and seeing his results using the spray-on liner U-POL, I went with that. U-POL is a two part product that seems super durable. It sprayed on very easily and clean up was quick and simple. As always, the hardest part
is the prep; sanding/degreasing.
U-POL
First thing was to remove the flares, mirror backs and bumperettes.
Front flares have four 10mm nuts inside the fender. I accessed the front two by removing the turn signal and the back two through the rear engine bay ‘port’. There are also two 10mm bolts one the outside at the front and rear, and one clip near the door.
Inside fender:
Engine port:
Rear doors have two 10mm bolts (top and bottom) and two clips. The rear quarter panels have two 10mm nuts, two clips, and one outside. You have to remove the mud flap and drop the front of the bumperette to get to the last bolt. The mud flap has six 10mm bolts and the bumperette (to completely remove it) has one 10mm bolt (inside the wheel well) two 12mm bolts and three 8mm bolts. (Mirror dismantle consisted of 6 screws. Two outside, four inside)
Inside rear QP:
Flareless:
Prepped bits. I sanded using a palm sander the hand sanded parts the palm sander couldn’t get. Taped off the areas I didn’t want liner on and wiped everything clean with xylene.
Masked for trim. This is just the outline of the area I wanted to cover. I had the whole truck covered in plastic for the spray.
Freshly sprayed parts and trim.
I drove around like this for two weeks. I was waiting for the flare gaskets from CDan. I liked the look of it and considered leaving it like this. I’d already sprayed everything at this point and didn’t want to waste my efforts though.
New flare gaskets and neoprene fender washers from Home Depot (next to original fender washers).
Gasket and neoprene washer on flare. The red is the backing tape for the adhesive that attaches to the fender. When installing, I pulled back a small tab of the backing tape. This let me maneuver the flare around a bit without it sticking to the fender before I wanted it to. Once I had the backing nuts hand tightened, I pulled the backing tape off.
Reinstalled flares.
Mirror (before & after).
Final product.
Before:
After:
Awesome! It looks great! Mine is still holding up great and has not faded at all.:cheers:
Glad it's still holding up. I won't be using the roll on stuff ever again. This was just too easy.
BTW: Thanks for the tip Simon! ;)
The flare lining looks amazing! The mirror back is the best part in the comparison pics. Looks like you are set up with an air compressor for this spray on job?
On a side note, do you have any lift in your pictures? The tires you are running look good but it's hard to tell if you have lifted it yet. Maybe it is just appearing to have more clearance around the tires without the flares on?
That looks REALLY nice! Looks like you took your time and did a great job. Hmmmm, gives me ideas as you looks just like mine, black and no POS factory rack or rear deflector.
How nice of a spray gun did you need to use? I have one that came with my compressor, but I'm sure it's not the best. Did you find spraying that material was pretty easy.
Word!
Dig the mirrors the most!! what a great solution for organic pin-striping!!
I understand the point of using liner since its pretty easy for anyone to do at home compared to repainting, and a little more durable with pinstriping on trails...
But to me it seems like taking a top of the line painted trim model vehicle and trying to make it look like the bottom of the line model with unpainted plastic trim - like those Honda Element things.
On a side note though, has anyone done this to an LX450? I know the flares are different with the LC and LX.
Personally, I think it blends very well and does not stand out or outline the vehicle. Never heard of that product but it looks quality and taking your time has really made something to be proud of.
:beer:
Nice write up and work. Having done mine with the roll-on for comparison I have to say the finish of your liner looks much better. Good idea with the mirrors.
The mirror (before) is a good example of how the flares also looked close up.
Yes, you need a compressor for this application.
No lift, not yet. I have it sitting on the garage floor, just haven't done it yet.
Function not fashion. My truck is all scratched up and will continue to get scratches. No point in re-paint. Just made the finish a little more durable.
Unlike many here I like the looks of the cruiser with the fender flares installed. I was going to have mine Line-Xed but now that I have seen how U-POL looks and works I think I have changed my mind. How thick can it be sprayed on? With the kit you bought would I have enough to spray the lower half of the front and back doors as well? What grit did you uses to prep everything?
Satin black rims will be in the works as well. I like that the U-POL closely matches the texture of the Safari Snorkel as well.
Man those cats hang low. Nice rig.
Hey what's up with the portals? I thought you where installing those. What happened?
