OME too short?
Redding, CA
OME springs too short?
Was reading the latest Toyota Trails magazine last night and came across a question about shackles on an FJ40. Mark who answers the questions in the technical help section answered the question and in his answer referred some more information in the May/June 2006 issue. So like any interested person would do I grabbed that issue and reread an answer to another suspension question. In Mark’s answer he stated some reasons why he does not like the barbell type of shackle. Duly noted and then went on to say that in his opinion OME springs are too short. This is what grabbed my attention since I think it is the first negative thing that I have read about their suspensions. I’m so interested because I’m real close to forking out all the $$$ to get the Dakar version of that suspension. So, are the springs so short as to screw up the shackle angle and if so, why do I read nothing but good things about them? Like to get some more opinions and possibly even Mark’s elaboration on why he thinks they are too short.
Suffering from paralysis by analysis.
I have a situation regarding OME on the rear of this 1965sb pick-up.
After five years of resto work, I'm down to wheels and exhaust before start
up. I've done all the searches and couldn't find a for sure easy way to get the
rear wheel centered in the well. I found one suggestion by removing leafs to
let the springs relax but the instructions were vague. I'll see if I can post a pic.
Welcome.
You can drill the spring perch on the axle.....no big deal.
I have used/installed a number of different lift springs and this is usually done to center the wheel in the opening.
Good luck!
-Steve
I've only laid hands on about half a dozen OME systems under '40s so my sample is limited. That said, in each of these rigs, the springs were short enough that the (stock or OME supplied replacements) shackles sat at a vertical angle at best. Under droop the shackles would invert.
A longer shackle helps the inversion problem, but does little to help the angle.
IMHO the OME FJ40 springs need to be a couple of inches longer.
Mark...
Mark...
This is so True......I installed a set just last week that when I let the truck down the springs inverted on their own.. the supplier suggested longer shackles or remove one of the longer leaves.....The customer doesn't want long shackles plus that would raise the rear more.......and if a leaf is removed that would lower it some....the problem seems to be gett'n worse.......
I just ordered a kit, any other sugestions?
Mark...
The Bitch'n part is when you install for the public and you have given a labor quote....and have to waste 10 or so shop hrs. trying to make the crap come out wright......
another suggestion would be cut your shackle mount off and move it back an inch or 2 to get the shackle angle right
My 4x4 shop hadn't ordered it yet. I won't move the shackle mount. I guess i more worried about the wheel not being centered.
Anyhow, any other 2-3" spring lift kit to suggest?
CCOT advertises their HFS springs are longer, but I have no personal experience with their springs.
why worry about the wheel being centered :| they're 40's.
i'm tipping if the HFS kit doesn't come with driveshaft spacers, the extra length will be on the shackle side of the spring pin, thus not moving the rear axle any further forward.
It is going to rub my fenders, and the last thing i want to do is cut them.
I recently had OME installed on my 76. The rear shackle is very slighlty tilted forward. The shackles have "anti inversion" ends on them. I haven't had any problems yet and I did a couple of pretty good trails at Moab last month- Fins & Things and Porcupine Rim. What are the potential problems with a vertical or near vertical angle? Do the anti inversion shackles prevent the only problem (inversion) or are there others? My son is thinking about going with OME and we'd like to avoid any future problems.
Thanks
From the way I understand it if the shackle is vertical or angled the wrong direction you are not realizing as much flex from your suspension and your ride will be harder. Additionally if your setup optimal you would not have a need for anti-inversion shackles. From what I have heard the HFS springs are longer thus providing a better shackle angle. Would love to see some actual measurements of HFS and OME and/or some uninstalled pics. I’m leaning towards HFS.
I have been running OME springs on my FJ40 for about 5 years now.
I also have 1" longer than stock shackles in front and 2" longer than stock shackles in the rear.
The front shackles are nearly vertical, and are an 'anti inversion' type of shackle. The front flexes OK
The rear shakles sit at about a 60 degree angle and are also an anti inversion type.
I have no problems with articulation, ride or handling.
In fact, the reason I am so hesitant to do a spring over because the truck rides and handles so well on the freeway.
Stick the whole OME suspension on the truck, and run it.
It does have some engineering flaws, but the suspension works pretty well for what I do with it, and I beat the snot out of my truck.
TMACK,
Do you know if the centerbolt holes are at the midpoint of the length of each spring? They usually aren't and one end of the spring from the center hole is longer than the other. If the difference is not large reversing your springs end for end might get those axles/wheels better centered
It's not a dangerous or problematic thing to do. Many people do it at both ends of their trucks to gain a few inches of wheelbase.
Do you feel the wheel is centered?
I run ome on my bj70 and it's fine the shackles sat vertical until the springs broke in. I've never inverted a shackle or come close(yes it does have the anti inversion though). I don't run hard core trails but I run medium trails and those that have been out with me know I flex what I have to the fullest. You have to realize what the OME system is designed for. Rough roads not rock crawling. Personally I feel I use the OME system for what is was designed for here in colorado running rough FS roads and passes. I like the ride I get and the flex it provides. I would recommend them and buy them again for these purposes.
TMACK in your pic I would put sand bags in the back. The spring and shackle are going to rotate back and up as desiged when you have a full load in the bed. At that time it will be centered.
I cut the wheel wells and I am running fender flares, but that was because I was getting alot of rub, but I am also running 35" tires.
The OME suspension, as a whole, was designed to be bolted into the truck, and run a 33" tire with minimal to no modification.
The springs are arched, so as the tire moves up, it will also move backwards a little.
If you are looking to have the tire centered in the wheel well when the truck is sitting on flat ground, you will have problems with the tire moving backwards and into the rear quarter panel.
Run the OME suspension SYSTEM, and if you are worried about rubbing, lower the bump stops.
This is exactly how I'll be using FJ40 so maybe not so bad eh? Lotta $$$ so want to get it the best I can for my purposes the 1st time around! Probably won't be doing anything for another month anyhow so I have some time to gather some more opinions.
