For Sale Parting out a Mustard Yellow '75 FJ40
jstncse
Crawling over something
Albuquerque
Recap
[STRIKE]Excellent windshield frame $250+ shipping[/STRIKE]
[STRIKE]Fuel tank very clean with sending unit $100+shipping[/STRIKE]
Fuel tank cover $50+shipping
[STRIKE]Overflow bottle with cap and bracket great shape $40 shipped[/STRIKE]
[STRIKE]Bib $100+ shipping[/STRIKE]
[STRIKE]Instrument cluster in great shape $100 shipped[/STRIKE]
[STRIKE]Fair speedometer cable sheath is chafed in one spot $20+ shipping[/STRIKE]
Heater valve fair 10+ shipping
Mustard colored aprons great shape $50+ shipping
[STRIKE]Headlight buckets with good trim $15 each + shipping[/STRIKE]
[STRIKE]Matching gas door lock and ignition switch make offer[/STRIKE]
[STRIKE]Kick out vents $20 each + shipping[/STRIKE]
[STRIKE]Body parts cut out and shipped make offer[/STRIKE]
[STRIKE]Choke cable $25 sold[/STRIKE]
Fan switch $15 shipped
[STRIKE]Warm air cable $25 shipped[/STRIKE]
Fresh air cable $20 shipped
Hazard switch $25 shipped
Wiper switch $15 shipped
Glove box door 4 speed 2 screws missing $25 shipped
Ashtray
[STRIKE]Filler neck and related evaporation parts[/STRIKE]
[STRIKE]Cowl will be available, was cut for a radio and has some rust under the accelerator pedal area. Pictures upon request[/STRIKE]
Passenger side rocker panel and B pillar in great shape with very little rust
Driver side rocker panel and B pillar with rust in the corner below the B pillar
Everything is OBO,
http://i921.photobucket.com/albums/...0-A866-44E3-B1C3-C8A94B242701_zps4rrsepzv.jpg
[STRIKE]The windshield frame is in excellent shape and the wipers work, surface rust only. There are 11 small holes in the top of the frame from a bimini top. The glass is broken and will not be included, wiper motor not included $250[/STRIKE]
http://i921.photobucket.com/albums/...0-2178-44A4-A690-EB56DE9FF573_zpsxzt27df0.jpg
http://i921.photobucket.com/albums/...8-B495-481A-BD31-B4684EE0C476_zpsbb9cbhcv.jpg
[STRIKE]The engine sounds good and has decent compression numbers considering that the truck was parked for the last 2-3 years $300, $450 including clutch and bell housing
Dry and cold 115, 120, 115, 125, 125, 125
Wet and cold 125, 130, 125, 160, 160, 125
I can't explain the last three numbers, that is just what they were.
Brand new Marlin clutch and pressure plate, at least it was in March of 2009 and it can't have much time on it. $125
[/STRIKE]
Engine and clutch are gone
Fuel tank cover looks to be rust free and I would expect the tank to be also. If there is any interest I will pull them and post pictures.
The tub and cowl are actually pretty rust free but the floor was cut up to run the roll cage to the frame and of course the comp cut in the rear. The dash was also cut at sometime for the radio.
[STRIKE]The air cleaner looks to be complete but I am not sure [/STRIKE]
http://i921.photobucket.com/albums/...C-4A71-45ED-850D-E67036636580_zpshorwih5z.jpg
http://i921.photobucket.com/albums/...E-AC39-4539-8A98-63FED47F5F85_zpsvpu0wx5r.jpg
I also have
[STRIKE]front bib, only has surface rust[/STRIKE]
[STRIKE]headlight bezel SOLD
headlight buckets $ Sold[/STRIKE]
[STRIKE]4 linked double triangulated rear using Ballistic heims and 1.5" tubing $500 including FJ40 rear[/STRIKE]
Comp cut roll cage built with 1.75" DOM, 56" wide and 77" long. $250
[STRIKE]All Toyota drive train parts available. I will be using '75 trans with the toybox but I have a decent '78 trans available. $150[/STRIKE]
Lots of other parts available. All prices are negotiable and do not include shipping. I will be happy to post or send pictures as requested.
Please post in thread or PM me.
Terrill
The tub is fair from the B pillar forward except for the floor,from the B pillar back it has no tub. The PO cut it and the tunnel up for rollcage install and toybox install, which was really a shame as it was really pretty rust free.
Night time bump
i need the gas tank section of the passenger floor... any chance you would cut that out for me?
I pulled the tank out this evening and the floor is is really good shape under the tank. So is the fuel tank and the cover for that matter. I will post pictures tomorrow. As for selling that part of the floor, I need to see what sort of interest the tub brings first. The rest of the floor is not in very good shape do to PO cutting.
PM me and we can discuss cut locations and value.
I could use a windshield wiper pivot arm if you divide up the wiper assembly.
Sorry, looks like the wiper motor is gone pending payment
Pictures of the fuel tank cover, fuel tank and the floor beneath it.
Tank
looking in the tank
The floor
and the only real rust is under this rubber strap. not bad at all.
Make an offer if you are interested
Updated the list and moved it to the top
looking for:
-both rear side marker lights if fully intact, good lenses
-both front turn signals if fully intact, good lenses
-drivers seat front outer triangular seat-to-floor mount
-#40 only in drawing below (1 needed)
all shipped to 11215. let me know. thanks!
