Trade 2002 LX470 or 96 LX450 for Jeep Wrangler
96 LX450 Info and Pics ~$12K
None locker
172K
EGR code
Has really nice seat covers very clean inside
4/1/1996 10 P.D.S.
4/1/1996 10 FULL TANK OF GAS
4/15/1996 17 INSTALL TOW HITCH
4/15/1996 17 INSTALL GOLD KIT
4/22/1996 125 INSTALL RUNNING BOARDS INT #200390 ---COMPLETED
4/23/1996 126 INSTALL ROOF RACK INT #200394
6/19/1996 2157 1000 MILE SERVICE
6/19/1996 2157 INSPECT AND CORRECT FLUID LEVELS
12/5/1997 18327 --REPLACED MISSING CENTER CAP.
12/5/1997 18327 AIR BAG LITE ON CLIENT STATES --C
4/9/1999 32987 STATE INSPECT/I-M TEST
4/9/1999 32987 CERTIFIED PRE-OWNED PDI
4/9/1999 32987 OIL SERVICE FOR MILEAGE ON CAR
4/9/1999 32987 REPLACE ENGINE OIL WITH PREMIUM V
4/9/1999 32987 REPLACE AIR FILTER
4/9/1999 32987 INSPECT STEERING GEAR BOX FOR OIL LEAKAGE
4/9/1999 32987 INSPECT BRAKE PADS AND ROTORS FRO
4/9/1999 32987 COMPLETE DETAIL SPECIAL
4/9/1999 32987 REPLACE FRONT AND REAR BRAKES
4/9/1999 32987 FOUR WHEEL ALIGNMENT-SPECIAL
4/9/1999 32987 ROTATE & BALANCE TIRES-SPECIAL
4/9/1999 32987 HEADLIGHT UNIT (ONE SIDE) R&R
4/14/1999 32989 TOUCH-UP
11/9/2000 60157 ANTENNA MAST IS BENT REPLACE PER CUST AUTH
11/9/2000 60157 CHECK ENGINE LIGHT IS ON CUST STA
11/9/2000 60157 BRAKE LIGHT COMES ON AND OFF INTE
12/28/2001 82202 BATTERY R&R
12/28/2001 82202 STARTER ASSEMBLY R&R
4/9/1999 32,987 Replaced front and rear brake rotors/pads
12/28/2001 82,202 Replaced starter assembly
1/1/2010 - New O2 sensors
10/1/2010 - Front axle rebuild (bearings, seals, grease), front/rear diff fluid change
11/1/2010 - PHH
12/1/2010 - Tranny fluid change, coolant flush
3/1/2011 - New PCV hoses, valve cover seal, spark plug seals, oil pump seal
9/10/2011 159,300 Oil+filter change
9/19/2011 159,500 New wheels/tires
10/8/2011 160,200 New windshield and OEM seal
10/9/2011 160,200 New Bilstein 4600 shocks, OME stock height coil springs
11/12/2011 161,150 New belts, OME steering stabilizer
2/5/2012 163,040 Valve cover gasket, PCV, PCV grommet, throttle body gasket, VSV for EGR, spark plugs,dizzy o-ring
spark plug tube seals, heat tape around harness, various vacuum lines,
2/18/2012 163,320 EGR vacuum modulator
2/21/2012 163,350 Set timing at 6°BTDC (was previously at 0°, spec is 3°BTDC)
3/31/2012 164,300 New battery, oil+filter change
4/25/2012 164,750 New spare tire
5/8/2012 165,245 Greased knuckles
5/9/2012 165,395 New blue hub fan clutch
5/14/2012 165,750 Greased u-joints, slip yokes
5/15/2012 165,780 Front/rear diff fluid change (Mobil 1 synthetic 75W-90)
5/17/2012 165,795 Transfer case fluid change (Mobil 1 synthetic 75W-90), relocated diff breathers
8/2/2012 168,250 Tire rotation (5 tire rotation pattern)
8/18/2012 168,450 Reset bearing preload (20 ft-lbs)
9/7/2012 168,800 Greased knuckles
9/22/2012 169,415 Replaced ignition wires, distributor cap, rotor, set timing at 3°BTDC, oil+filter change
2/16/13 172,262 Rotella T6 oil and Toyota filter
8/16/13 179,000 new ceramic pads and rotors all around.
9/16/2011 New badges $ 72
UltraGauge $ 87
Tires/wheels/mount/balance/lug nuts $ 1,625
Floor mats/cargo liner/vent visors $ 360
Front seat covers $ 142
9/22/2011 Front bumper + repaint $ 300
10/8/2011 New windshield+OEM seal $ 310
10/9/2011 New Bilstein 4600 shocks, OME stock height coil springs + steering stabilizer $ 699
10/25/2011 Steering shaft dust seal $ 11
Parking light lens $ 10
Side marker light grommet $ 1
11/1/2011 Rear seat covers $ 147
Land Rover cup holder $ 32
11/12/2011 Belts (3) $ 21
11/25/2011 Mirror bolt cover $ 6
11/27/2011 Scion T1806 head unit $ 115
1/15/2012 Dash lights $ 11
1/18/2012 HID headlights $ 40
LED interior lights (domes, map, doors, license plates) $ 80
1/28/2012 Hatch light fixture/LED panel $ 30
2/4/2012 VSV, spark plugs, tube seals, dizzy o-ring, valve cover gasket, PCV $ 250
2/8/2012 LED tail lights, clear corners/blinkers $ 165
2/18/2012 EGR vacuum modulator $ 60
LC console swap $ 20
Corner/blinker wiring $ 5
3/31/2012 Backup LEDs $ 35
Depo headlight housings and bulbs $ 267
LC grille $ 75
Battery $ 80
4/25/2012 New spare tire $ 271
5/9/2012 Blue hub fan clutch $ 129
5/15/2012 Front and rear diff oil exchange, diff plug gaskets $ 90
5/17/2012 Transfer case oil exchange $ 25
Relocated diff breathers $ 40
8/3/2012 Wheel $ 110
Wheel refinish $ 150
Spare tire mount and balance $ 20
8/20/2012 Axle flange studs/nuts/cone washers $ 48
9/22/2012 Ignition wires/distributor cap/rotor $ 64
11/1/2012 Front mud flaps $ 60
12/1/2012 Wheel center caps $ 75
Keep the 80 and 100, but trade-in the gf. Just kidding Lee! :)
Is there a cash price for the 80?
You have a very nice rig. I dont have a Wrangler to trade you but Im interested in purchasing it.
A few Q's:
Has the head gasket been replaced?
Can you post some interior pics?
How come there is no record from 2000 to 2010?
A few Q's:
Head Gasket has not been replaced and shows no signs of needing it.
Interior Pics can be seen here.
http://www.flickr.com/photos/benschmittphoto/sets/72157632542584848/
Before me the two previous owners were Mud members.
This is the thread that 2 E L O bought it off of. I bought it off of 2 E L O. This is why no "Lexus" dealer maintenance shows on the records.
https://forum.ih8mud.com/fj80-fzj80-lx450-hdj81/512929-1996-lx450-fj80.html
Update for the 470. She is getting new brakes and half shafts today. While in there they are going to pack the bearings. They are also doing the timing belt and wather pump, which should finish off the 90K service. In the next week or two I will also be installing a new Nav unit.
let us know when the 2002 is up for cash sale. thanks, T
Are you SURE you want a Wrangler? They are a real novel and fun idea until you own one. I have owned 4 Jeeps. My last 3 were a 2000 TJ Wrangler (fully built) on 35's. Then a 2000 XJ on 37's and finally a 2002 WJ on 33's. They all were constantly breaking down and only the WJ was comfortable. The Wrangler was by FAR the worst of the 3. I HATED it. The black hard top would just cook the interior. The short wheel base with stiff shocks road like a retarted 3 legged mule. I was VERY happy the day I sold that Wrangler. They look soooo fun until you own one. There is a reason why I am back in an 80 and plan to stay there. Going to a Wrangler is definately going in the wrong direction. Unless your getting a 2013 JK 4 Door Rubicon with the new 3.6 then STAY AWAY from Jeeps. The ONLY upgrade would be a new Rubi; but those come at a huge premium. Might as well just keep the 100 for daily driving and build the 80 for the trails.
I got your post on my "wanted" add. Your 80 is beautiful and I know my buddy would be quite interested, but if I am reading your sig right I think your in Indiana. Is that correct?
Im very interested in the 80's series. I PM'd you, but I do not know if it worked since I am a new member.
Please reply to this if you did not receive my PM and we will find a way to get in touch.
What do ya'll have to trade? Looking for maybe a manual coupe with a V8. Muscle car etc. Anyone looking to get out of a toy for a family rig. I don't need 3 rows of seat when it's just me and the :princess:
Bump this back up for the 80. I appreicate the 100 series and its amazing ride more than the offers I have been getting on her so I'm leaning towards keeping the 100 because it DD sooo nice, and we really have no use for solid axles looking for 12k for the LX450.
jeep
Trade? 04 Jeep Wrangler Unlimited (2dr lwb), mildly built and only 37k miles. Can send more info and pics if interested, thanks!
