I'm a bit confused what you are asking here.
If you mean can the hinges be assembled once the bearings are pressed in, yes. I double checked before assembly.
Yes, that's what I meant, sorry about the poor phrasing.
I'm still trying to figure out if I received the right bushings. They will not fit over the 8mm rod I'm using. The rod fit perfectly in the hinge. An 8mm bolt does fit at least the threaded part.
On the zerk, the only issue I see there is that the bushings are pressed in so all it would do is fill cavity between the bushings. Not sure how effective that will prevent rust underneath the bushings or at the "fixed" side.
Right, I understood that you are concerned about rust where the bearing seats in the hinge thus the molebdenum paint suggestion. It acts as a lubricant in industrial apps but in your case I was thinking it would work as a material that could possibly survive the press fitting and stay in place under the bearing without flaking off.
Onto a partial update... I've finally cut apart all the hinges and I'm working on cleaning them up. (SouthBostonFJ, if you want to borrow this set, they can be available)
