Fuel Lines
MT
Anybody find a source for original type fuel lines and fittings? I have a lot of it, mostly in 6" lengths...the stuff seems to be very durable. I would rather not do the rubber stuff with hose clamps, but will if I have to...
I used yellow fuel line (tygon?) from McMaster Carr. I can get you the number. It's the right thickness, but a lot more flexible, I was worried about it collapsing on the suction side of the pump, but no problems (yet).
You can reuse the nuts, they come off and there's a hose barb underneath, slide on the hose and stake (or screw) the nut back in place.
Type Fuel and Lubricant Yellow Tygon PVC Tubing
Plastic PVC and Tygon
PVC Material Tygon Formulation PVC
Tygon Material Tygon PVC
Material Tygon PVC
Tygon Forumulation F-4040-A
Shape Single Line
System of Measurement Inch
Reinforcement Unreinforced
Semi-Clear Yellow
Color Semi-Clear Yellow
Maximum Pressure Range, psi Under 100
Low Temperature Range -99º to -1º F
High Temperature Range +101º to +200º F
Operating Temperature Range -35º to +165º F
Durometer Range 51A-70A (Soft)
Durometer (Soft) 57A
Durometer 57A (Soft)
For Use With Biodiesel and Coolants and Gasoline and Heating Oils and Kerosene
Fittings Used Barbed
Specifications Met Not Rated
What I've found playing around with this stuff recently, when you go to reuse the original fittlings: The hose is thinner, so the cone washer needs to be shimmed with something. I use teflon tape to build up the outside of the hose then slip on the cone piece and the staking nut holds everything secure.
It does harden up over time. ;)
