Fuel Lines
MT
Anybody find a source for original type fuel lines and fittings? I have a lot of it, mostly in 6" lengths...the stuff seems to be very durable. I would rather not do the rubber stuff with hose clamps, but will if I have to...
I used yellow fuel line (tygon?) from McMaster Carr. I can get you the number. It's the right thickness, but a lot more flexible, I was worried about it collapsing on the suction side of the pump, but no problems (yet).
You can reuse the nuts, they come off and there's a hose barb underneath, slide on the hose and stake (or screw) the nut back in place.
Type Fuel and Lubricant Yellow Tygon PVC Tubing
Plastic PVC and Tygon
PVC Material Tygon Formulation PVC
Tygon Material Tygon PVC
Material Tygon PVC
Tygon Forumulation F-4040-A
Shape Single Line
System of Measurement Inch
Reinforcement Unreinforced
Semi-Clear Yellow
Color Semi-Clear Yellow
Maximum Pressure Range, psi Under 100
Low Temperature Range -99º to -1º F
High Temperature Range +101º to +200º F
Operating Temperature Range -35º to +165º F
Durometer Range 51A-70A (Soft)
Durometer (Soft) 57A
Durometer 57A (Soft)
For Use With Biodiesel and Coolants and Gasoline and Heating Oils and Kerosene
Fittings Used Barbed
Specifications Met Not Rated
What I've found playing around with this stuff recently, when you go to reuse the original fittlings: The hose is thinner, so the cone washer needs to be shimmed with something. I use teflon tape to build up the outside of the hose then slip on the cone piece and the staking nut holds everything secure.
It does harden up over time. ;)
onto my next nightmare. these look like just compression fittings where the upper nut should spin off, but everything just spins and spins and doesn't separate. is there a trick?
Sorry no pics, but the fittings are three pieces and work like a hydraulic hose end. It s a compression fitting of sorts. The piece with the threaded end has nothing but a hose barb on the other end. The other nut is not threaded, it is a staking nut with a tapered collet inside. You can take it apart by clamping the threaded piece in a vise and just tap the staking nut off the collet with a little drift.
The real challenge will be finding a hose with the appropriate O.D. to make it all go back together again.
Red Line Cruisers has a repop kit for the early clear fuel lines.
Red Line Fuel line Kit
The kit doesn't 100% work for FJ25s.
The tank to filter line works, but on a FJ25 the filter to fuel pump line is longer than what is in the kit. Fj25s fuel filter is mounted on the fender making it farther away from fuel pump.
Since they are made to order maybe they can make one longer.
$322...ouch
the line i got isn't clear, but once it browns, i'm sure no one will notice ;)
it's also a bit thicker, but it appears to hold well and i'm running with it. if it doesn't work, i'll figure something else out.
here's a pic all four pieces that make up the fitting.
It sure is a weird fitting. Here is the line that I used:
https://www.amazon.com/gp/product/B001OKBHES/ref=ppx_od_dt_b_asin_title_s03?ie=UTF8&psc=1
Pretty much and exact replacement.
Pics from when I redid mine:
