While having some work done on my alternator, I'm afraid the rebuilders made a mess of my vacuum pump.
1) It makes a crazy whirring / droning noise that is independent of engine speed. If I use up some vacuum it will go away and come back when the vacuum is strong enough again. Seems like a leak internal to the pump.
2) After coming to a stop at a stop light, the brake light comes on and off, apparently vacuum related.
I had no issues with this pump before the rebuilder touched it.
I strongly suspect that they did not properly replace the o-ring between the pump & alternator, the o-ring between the end-plate and the casing, or lube the carbon blades at reassembly.
Do those issues seem like a reasonable cause?
I'd like to pull the pump off, lube it, replace the rings with the proper ones and hopefully be done with this fiasco.
They told me these o-rings are hard to find at the local suppliers.
Does that make any sense? If I take the pump to any local parts store I should get what I need right?
