3b exhaust flange drawing/cad?
Longmont, CO
Anyone have a CAD file or dimensioned drawing of the 3B exh flange. Someone was selling laser cut flanges on here, any chance they'd share the drawing? Don't worry, for personal use...
a beer box, a hammer, drill press and grinder???
why make it hard
If you'd like, I have a 13BT exhaust manifold I can photocopy next to a ruler, and send you the scan...
Or frankly, I'm not going to be doing my turbo anytime soon, so I could mail you the manifold (or my turbo adapter, which is a lot smaller).
okay, so its a little harder. but still, start by clamping your old manifold to whatever your using to bolt to your engine. me, i used 1/2 plate. drill one hole, put a bolt through it. drill two, another bolt on opposite side. then drill the rest. takes about an hour.
I realize there are a hundred ways to magguyer something together, its not like I've never drilled a hole before. (Although you left out how to drill the big exhaust holes themselves - thats a bit harder than bolt holes)
But I'm asking for a CAD drawing or a picture with dimensions.
I started to do this to my 2H manifold, if they are the same (size opening and bolt location) i could finish what i started and send you a copy. Its a revit file though, but i can still cad it for you...
Buy an exhaust gasket and go from there.
~John
Already en route :D. OEM gaskets seem to be disco'd though, so I was concerned about the tolerances/fit of an aftermarket gasket.
Also, as I type this I realize I have a full gasket set in my rebuild kit sitting in the closet and could have just pulled it from there. :doh::censor::doh::censor:
I had this exact same problem months ago when replacing my rusted exhaust pipe. I cannot recall what I did. The last idiot mechanic that the last owner took this truck to did a bad butcher job on this exhaust. I had to buy new brackets that were missing.
I guess it is a chevy three bolt but you know, I went to the lordco in Richmond and none of there three bolt flanges would match up. Toyota wants a arm and a leg for there muffler for this truck. The original one is okay.
Bah, mud, you've failed me!! :grinpimp:
Fine, I did it myself. Attached are two versions, one is very square and simple (and wastes lots of material), the other is very curvy because... why not. Your waterjet/laser guy should be able to cut right from this file. Both are a single piece for all four exhaust ports.
<bad link>
EDIT: Updated links below.
Just updating this thread for posterity.
The file above (<bad link> EDIT: http://www.drewmaurer.com/3b_manifold.zip) contains two versions like this:
attachment.php
The top one has large rounded corners to make welding a log-style manifold easier. The bottom one is an exact copy of the exhaust gasket, plus extra material between runners to save on waterjet time.
I also just uploaded a second version with some extra meat around the ports for tube style manifolds (<bad link> EDIT: http://www.drewmaurer.com/3b_manifold2.zip)
attachment.php
All three have the same hole pattern and fit fine:
attachment.php
attachment.php
attachment.php
