I didn't want to hi-jack Luke's thread so here is the deal. This is unbelievably frustrating. I have read they are hard to bleed. I rebuilt the 2 front calipers, figured I had a sticking caliper since it was pulling to the left. Brake pedal was fine prior to this. I bleed front lines firm pedal but once engine is running it's soft. So I bleed the rears and the LSPV. I have read everything there is to read on bleeding 80's on MUD, ABS should not be an issue. Re-bled the whole system again tonight, pedal is not much different when running as compared to when I first bleed the fronts. Used the manual pump hold method with
Used vacuum and the new Motive (which is cool by the way). Then I used the pedal pumping with power bleeder. I have never had this much trouble bleeding brakes, there is no air coming out and fluid is nice and clear
I just don't understand it. I guess I'll ask the local Stealerships for LC discount and go from there. I would rather have them on the hook for a set price rather than someone like Justin getting stuck trying to figure it out.
of a time getting the rear line re-attached. Didn't get a chance to re-bleed, I'll do that tomorrow.
Brilliant! I'll give it back in a week, I promise.......
