What AGM battery charger are you guys using? I need to get one as I don't drive the 80 as often as I should and the battery will drain between drives. I have the IBS duel battery system. The batteries are seperate unless I override them so I can charge both at the same time. I was looking at: Battery Tender 022-0165-DL-WH 12-Volt 2-Bank Battery Management System http://www.amazon.com/Battery-Tender-022-0165-DL-WH-12-Volt-Management/dp/B000NCOKV0/ref=sr_1_23?ie=UTF8&qid=1354980444&sr=8-23&keywords=agm+battery+charger or Schumacher SC-10030A SpeedCharge Automatic Charger and Maintainer http://www.amazon.com/Schumacher-SC-10030A-SpeedCharge-Automatic-Maintainer/dp/B001MYWBF0/ref=sr_1_1?ie=UTF8&qid=1354980701&sr=8-1&keywords=Schumacher+agm+battery+charger Any one have one they like? Or advice on the two above?
