I'm having a bit of a problem hooking up my interior winch control. I have the Slee relay circuit that I want to use, but have a Smittybilt winch which is a three wire winch (relay is made for a five wire warn type winch). I tapped into the winch right before the remote plug. Hooked the in/out and power wire from the relay circuit to the three wires coming from the winch, then the in/out wires from relay to antenna switch. So far, so good. I have power to the relays because I can hear them click when I press the in and out buttons (already relabeled). So far no power to winch. I then connect the remaining two wires from the relay circuit to the power wire and presto the winch has power, BUT it's either both in or both out only!!
Any ideas on how I can make it work with the Slee relay circuit? I would also like to incorporate a hazard switch as an interior power switch in case I might bump the antenna switch by accident, but that doesn't seem too complicated.
Can anyone help an electrically challenged newbie? I would like to try to do this myself rather than having something made.
Thanks,
Dan
Thanks,
Dan
