1995 No Start
Hey Rob,
I'm assuming that the starter wire you're referring to is the small gauge wire that triggers the starter solenoid, and not the 4 gauge cable from the battery. If so, I would suspect the wires in the Neutral Safety Switch (NSS)as they have been a problem for at least half a dozen folks here. The NSS is on the right side of the transmission in a 95 and has a large plastic connector with a bunch of small gauge wires and two larger gauge wires. The two large wires are the signal in from the ignition switch and the signal out to the starter. If the connectors are corroded/broken (mine were) you will have an intermittant start problem. I'll try to find some of the older threads on this problem.
This one here (https://forum.ih8mud.com/80-series-tech/402676-neutral-safety-switch-starter-problems.html) has good info on the problem as well as some links to the other threads about this.
Thanks Adam, good bit of reading, i definitely not getting the signal as posted in one of the earlier posts, the dash is only showing three icons.
Pulled the plug and it looked like new with so much oil bathing the wires from numerous oil leaks.
At this point I guess I should check continuity.
Rob
The two wires in mine didn't look broken until I went to take them out with a terminal pick. One was totally corroded and broken off and the other was tearing through and corroded. The rubber plugs can make it seem like the splices are still solid, but you can't tell for sure until you pop them out and eyeball them.
If they are indeed good, continuity is the next thing I would check (as you said). The circuit is pretty simple. Do you have an EWD for this rig?
You da man, looked good but not good.
Where can you find those crimps?
Went to lordco, Gregs and toyota.
Thanks for the help, could not of done it without this information.
Rob
From the second post in the linked thread :p
I'm guessing you've already read through this thread https://forum.ih8mud.com/80-series-tech/233993-starter-neutral-safety-switch.html (I recognize the photos!), but did you follow the second link posted by Romer for this thread https://forum.ih8mud.com/80-series-tech/172212-intermittant-starter.html? Post 36 in there has the part numbers for the two splices (82998-12480) and the plastic connector (90980-11332), posted by yours truly ;)
To repair the harness, peel back the plastic loom, cut out the old wire at the same length as the replacement splice, solder/crimp them in place, use some good quality waterproof heat-shrink to seal the joint and reassemble the harness. I'd also recommend replacing the plastic connector body if the gasket inside it (the little ribbed orange thing in the second photo) is torn or mangled.
I was out on the island last summer visiting family in Nanaimo, Victoria and Duncan (an uncle of mine owns this beautiful old girl: The MV Songhee). If I had known you guys were in town there I would have stopped by and said hi. Next time for sure!
:cheers:
:cheers:
Oh for sure drop bye, that boat is beautiful.
Does it run on the outside by Tofino, I use to commercial fish for a short time.
Thanks again..
Rob d
