Lower rad hose drain plug??
Hey boyz! I tried to drain my coolant the other night via the aftermarket rad petcock (PO installed it, not me!) .. I couldn't access the plug. I then tried draining the coolant out of the engine block. It started out fine, but soon gushed out all over my garage floor. I am sure it was stupid of me to think that nice little stream of coolant was going to stay that way! I was pissed.
Anyway, I was wondering if anyone has used a temp sensor insert like the one below as a lower rad hose drain?
Installing it into a silicone hose with constant torque clamps should be easy enough. I realize it also creates two more points that have the potential to leak .. but I will carry a spare OEM hose. Any other ideas are welcome if this one is flawed!
Thanks!
Thanks!
