Ivan Stewart Toyota Trd Wheels For Tundra Tacoma
CANADA
wondering if these fit the 80 series and what the backspacing is, does anyone run them and do they fit with the center caps on
I believe they won't fit without any modification since those have smaller center bore. However, I've spotted an 80 with those wheels before and assumed that the owner must've used some kind of spacers to make them fit.
I know this for a fact because I've bought a set of 18'sBBS TRD (Tundra's TRD option) with an intetion to put them on my 80 but they also have samller bore size.
Nice looking wheels though.
I Have them on my 80, with spacers.
Spacers Spacers where do we get these spacers?? Any issues with spacers with these?
They have correct backspace but the center bore is too small to clear the 80 hubs. They are difficult to balance and require special lug nuts to clear the walls of the lug holes.
Correct, Correct , and Correct., as Cdan typically is. Be cautious about what type of tires you try to mount on them b/c of the difficulty to balance. When they were first introduced, I had a set on an Ivan Stewart Tundra and the dealer sent two sets back to Toyota b/c they thought they were out of round. If you don't use the special McGards spline lugs, you can just get a thin wall socket from snap on etc that will fit inside.
In other words, I hope you like the style b/c they can be a pita!!
