Ditto, turbocruiser. Four drive wheels need four chains. I don't see how chains add stress to the differential seeing that the whole purpose of the differential is to account for motion imbalance between the wheels.
I think chains are more effective on the front axle. The front axle controls steering and the majority of breaking so, to me, it makes more sense to put them there.
I tried mine out yesterday actually. I was staying at a house in Tahoe with my friends and several inches of new snow had fallen the previous night. The snowplows hadn't made it to the neighborhood and a lot of SUVs and other cars were sliding around and getting stuck in the street.
I pulled out of the driveway to see how bad it was and somehow got a little stuck, even fully locked. so I put the chains on, loaded up the Cruiser with four other friends and our gear and headed to Squaw Valley. Made it out of the neighborhood without any problem. I even had to plow a fresh track around another SUV stuck in the middle of the street.
My other friends couldn't get out. They had an all wheel drive BMW and Subaru Outback and were afraid to go out into the street. I called them from Squaw and they were bummed.![]()
If you are staying on level ground with even traction (liked deep snow on the road) no biggy. But if you are flexing out the suspension, and have intermittent/uneven traction, and are turning the wheels to full stop, think of the added stress on the front axle parts. A tire will spin down from high speed at no traction to a proper speed when it gets traction. With the chains on, they can grab pretty much instantly, immediately synching with the vehicle speed. In my mind, this means rapid changes in the torsional stress on the axle (and birfs). I should have said driveline before, rather than diff.
I have chains for all 4 corners of my truck, and would use them all if I needed (staying smooth on the throttle), but so far I have only put a pair on the back.
I'm guessing the no chains up front rule is from loose fitting chains, if they are loose and you turn, they can get into some parts that shouldn't be bashed with chains - just conjecture
Having driven with various configurations (and in a helluva lot of snow), IMHO IF you only have one set of chains, chain the front. You're better off pulling than pushing, and steering the front wheels versus a locked rear.
My tire chain education comes from my dad.
He owned a 1960 Dodge Town Wagon Power Wagon and that was the 4WD vehicle I grew up in (literally).
That truck went in more places than any sane person would take it and it was a true monster.
His chaining procedure was he would chain the front first and then chain the rear if he was not able to proceed. The only time he would chain the rear-only was in a steep descent.
His explanaton was that steering control was paramont and rear traction was secondary, execpt in the case of a downhill descent.
