Before I broke my truck on Sunday, I did a car off throttle body, IAC and MAF cleaning and inspection. Also replaced the PCV and grommet.
After I get the truck back in action and drive it around for a week or so we'll see if this cleaning helped my high start up idle and low warm idle in Drive. For 2 days, ran beautifully, then I killed it, but thats a different thread.
Here's a few tips on the process:
1) Use foam ear plugs to plug the coolant hoses.
2) The lowest of the three cables attached to the TB is easier to reattach before bolting the TB back on.
3) Put the lower TB bolts in their holes before putting the TB back on. Its really hard to get them in with a socket extension if they arent already in their holes once the TB is on the car. (I dropped one and had to remove the TB again to get it)
4) For the PCV removal, I used electrical tape reinforced with a piece of wire to plug hole under the grommet to prevent pieces of the grommet from falling in. Worked great.
Pictures:
Pictures:
