4runner Calipers
Dynosoar
Slightly Disturbed
SILVER Star
SoCal
Hi,
Does anyone know what the difference between the s12w (90-91) caliper and the s13w (92-95) caliper is. I got a screemin deal on a pair of s12w's and I'm hopping they will work.
Dynosoar
CDan would probably know.
1(800) 432-6668 Ext 8 ....Operators are standing by
Seroiusly, he'd be a good person to ask.
I believe that the earlier ones are 35mm pistons vs the 40mm pistons on the later ones. But on the earlier ones you don't have to grind the calipers to clear the wheels (at least I didn't).
chris
Would the reduced piston size affect stopping performance? I'm still planning on swapping the MC and doing this swap, but it would be great to be able to install a caliper without any cutting...
I have taken the caliper apart and measured the pistons they are 40mm (actualy slightly larger). I will call CDan today and post what he tell me.
There is a difference. I had the 92-96 rebuild kit and it will not work on the earlier ones. We were measuring everything standard at the parts store as I'm not sure the locals have heard of the metric system... but I think it worked out to 35 and 40mm.
I am running the earlier ones on my rig and the stopping power is great. I did not have to grind the calipers to clear the stock wheels. There was only minor cutting to the dust sheild.
Chris
This mod is really a no-brainer, i had to do a little grinding but thats probably just because im running rockcrawler wheels. As the pads have broken in a little bit ive really felt a difference in the brake performance, instead of feeling like the brakes were maxing out that last 20 feet of a stop i feel like ive got plenty of force to haul the truck down. I havent really hit em hard enough to lock the tires but there is enough force to make me have to pay attention to my steering when i get on the brakes hard, it wants to pull to the side when i get on the pedal hard.
Oh, and a little trick i found helpful is to use a golf tee to stuff in the end of the brake lines to keep the fluid from dripping out, i put in the master cylinder before the new calipers and the tees kept my fresh fluid from just draining out onto the floor.
Matt
After a lot of digging on the internet i found this.
89-91 calipers with casting mark s12w have four 43mm pistons
92-95 calipers with casting mark s13w have four 45mm pistons
2mm cannot make that much difference can they?
I got the set for a real fair price so I think I put some fresh seals on and give them a try.
Dynosoar
Hmm, i would think that you couldnt tell a difference between the two, and chris was saying the earlier calipers are a little smaller so if youre freaked out by grinding then they might be a better bet for you.
What kind of master cylinder are you planning on running?
I have a 1" master from a 4runner. The grinding dosen't bother me at all. I just happend to get a really good deal on these ones.
Dynosoar
Yeah, i was working on mine with a big ass grinder and it never even heated up the casting, its stout as s***. I was trying to find a good junkyard deal but ran out of time and ended up getting NAPA remans.
