Cleaning/Remove Rust from Factory Rims (1 Viewer)
Colorado Springs
My rig has those factory chrome wheels. They look pretty good, but have some surface rust in spots that I'd like to remove. I've been going at them with Nevr-Dull, but my elbows are running out of grease. What should I use to get rid of the harder to get surface rust?
If this would give me an excuse to buy a Dremel or some other new tool that would be great...:D
:princess: "WHAT DID YOU BUY THIS TIME?!?!"
I usually dont like to share my secrets but since its mud.....
Grab some aluminum foil and scrunch it into a ball. Dip the foil in a cup of water and then scuff up the rusty spots. Works like magic. To keep the rust at bay spray some fluid film on a rag and give the rims a quick wipe when youre done.
D
I use WD-40 and 0000 steel wool.
I'll try that too...in case my :princess: bitches about me using up her aluminum foil!
Toyota chrome is really tough stuff. If its really bad a wire wheel on a grinder works great, just did it to 4 really rusty rims and all it did was clean up the chrome, didn't hurt the chrome one bit. But now that the rust is gone I am going to paint them anyway...
Tony
I would clean wheels with good degreaser first. Then use #000 steel wool (Can start with #00 if really bad) with mothers (or alike). Always move in straight pattern. No circles. This will take off the heavy stuff. After that I use #0000 steel wool with mothers. That last polish I take off with a cotton buffing bit for the die grinder. You can get these at car paint places. Buy two. First for heavy cleanup and other for finish polish. I have done this to many sets of chrome wheels and works great. Some of the sets I've done I thought they where black when I bought them and turned out to be chrome. I love cheap cleaning solutions. Good Luck. Also there is a 1000 ways to do things and not just one is right....
I've heard of the Aluminum foil trick, but never tried it... Post up results if you give it a go.
Im tellin you man, works wonders. Its soft so it wont scratch the chrome as much as steel wool.
D
This works fast. Someone else posted this in a similar thread a year or two ago so I gave it a try. A little on a wet sponge takes the rust right off and polishes up nice.
Aluminum foil will be the first try since that's what I have at home....grilled up some potatoes in it this evening along with some steaks....woo hoo summer is here!
I hope to get my LC back Monday. It was at the garage since Friday...just saw a voicemail today that they called yesterday...I missed it!
