I would also advocate for dye. There are a couple things to be aware of: 1) the system has to be operational for the dye to circulate, which potentially means the loss of more refrigerant, 2) some leaks are difficult to find the dye, the hub of the compressor can hide it, or if it's in the evaporator box, it's hard to get in there to see it.
Common leak sites include the o-rings at the condenser hose connections, the o-rings at the expansion valve, hose crimps (look for oily residue), the hose and plate connections at the compressor and the compressor front seal or body o-rings.
I have an inexpensive (but bright) true UV LED dye light for $16.95 for MUD members.
FYI, I sell the following OE Denso A/C parts for FJ60's: compressor with clutch for $250 + a $25 core, the receiver/drier $31.33 and the expansion valve is $32.64. A complete set of o-rings is $4.57
If you have any questions, please call or e-mail
Thanks,
Rex
www.coolstreamac.com
rex@coolstreamac.com
1-888-438-9534
