Hi guys,
First things first. I am swapping front disc brakes from a FJ-60 to a 1968 FJ-40. I am also going to be swapping out the single circuit master cylinder for a dual circuit. I'll also be running new brake lines.
I have a pretty good handle on the disc swap portion of the build from numerous threads here on MUD.
However, I am still trying to figure out what dual circuit master to run.
Being that this a 1968 FJ40, It is hard to work around the dang rib, and I also swapped in a 2F with a stock carb, so running the 1978 FJ-40 Master/Booster I purchased for the swap is out. I have no problem cutting the rib, and I have no problem running a boosterless master as long as everything works, but is there another alternative?
What are you guys running for a Master/ booster combo that works with a similar setup?
TK
However, I am still trying to figure out what dual circuit master to run.Being that this a 1968 FJ40, It is hard to work around the dang rib, and I also swapped in a 2F with a stock carb, so running the 1978 FJ-40 Master/Booster I purchased for the swap is out. I have no problem cutting the rib, and I have no problem running a boosterless master as long as everything works, but is there another alternative?
TK
