Wife and I are both tall so I wanted to get the tank out from under the passenger seat so I can lower both seats.
I have a 4 link and custom made rear tub. I followed the same basic shape of the stock tub and had the metal shop bend it up. Got the sides bent and put it all together with the stock top rail. Rear crossmember has been moved back too - along with the axle. This setup left me with a nice open space between the frame and above the control arms for a gas tank.
Volume calculations placed it at around 19 gallons but I had to modify it a bit and with baffles I suspect around 18. I haven't filled it yet.
I lowered the rig onto the bumpstops to make sure the control arms don't hit the tank on full stuff. I have about 1mm of clearance
I may need a slightly longer bumpstop or elevate the bottom pad a bit so it's not so close.
The biggest challenge I had was sealing all the fittings at the welds. I am not a certified welder so after chasing leaks several times I sealed all the welded in fittings with lots of JB weld
