So after hearing all the horror stories (Like this: https://forum.ih8mud.com/40-55-series-tech/220710-heads-up-check-your-fan-blades.html) about the original old 4 blade F motor fans I decided to upgrade to the newer 6 blade plastic fan on my 65 FJ45 at the suggestion of others. I decided to ask my go to cruiser genius cruiserbrett which fan to use and he pointed me in the right direction.
Here's what I used:
-Newer mid 70's 6 blade plastic fan (non-clutch version).
-F engine fan spacer (I first installed it without but it was about 1/8" from the fan belt).
-Longer bolts (and lock washers) that I matched up to the fan and spacer.
Here's what it looked like before...
Here I lined up the spacer with the fan...
I removed the 4 blade fan and matched the old bolts up at the hardware store and left about 1/2" extra which was close to what came through with the original 4 blade fan...
Once installed, I checked for clearance. Here's a view of the spacing from the radiator (shroud not attached)...
View of the spacing from the fan belt (shroud attached)...
Final look...
Now I have piece of mind that the fan isn't going to destroy the old original radiator still sitting in this classic.
Thanks to those that suggested this upgrade before it let loose.
Here's what I used:
Final look...
