After reviewing many different threads, designs, contraptions, etc. I saw a set up that was posted by fellow mudder PScottBx.
I was looking for a sytem that was simple to use, clean from an installation standpoint, and most importantly--safe. I am sure there are many ways to improve upon the design. However, it meets all of my criteria and it only takes 10 minutes to take the top off and put back on--- and I can do it all myself. Oh yeah and I also needed to make sure the
was happy with the installation. Here is a list of items I bought:
--440# double line pull winch from Harbor Freight
--Uni-Strut from Home Depot (3) 10ft pcs
--(4) 16" pcs of chain-- This is used to secure the frame to the eyebolts which will need to be screwed into ceiling joists. This way the weight can be taken off of the winch.
--(4) caribiners
--(4) Wood eyebolts (screw these into the ceiling joints)
--(2) metal eyebolts (used as the connection point for the winch cable)
--Assorted hardware to assemble the frame
--Pipe Insulation (to cover frame so it does not scratch the top)
--Zip ties
--(4) bike hooks with the rubber already on them so they do not scratch the top
--4ft of 2.0" steel pipe
--couple of 2x6s so you can build a frame for the winch
I hope this helps. Sure has helped me enjoy the cruiser on these 70ish days. Please let me know if yo have any questions.
I hope this helps.
was happy with the installation. Here is a list of items I bought:--440# double line pull winch from Harbor Freight
--(4) caribiners
--Zip ties
I hope this helps.
