Photo Reference Needed
Lafayette, Colorado
Does anyone have a photo reference for where the speedo and parking brake cables should be routed between the frame, rear motor mount and the firewall on a 1972 fj40 with a 3-speed tranny? I didn't get a photo of that area before I pulled the motor and could use a reference to get it all back together correctly. It seems a bit cluttered around the clutch slave cylinder and clutch fork spring. Thanks. :cheers:
Found this picture on Jeff Zepp's Web site showing the lines running above the rear motor mount but I think they are just resting there during his restoration.
I'll keep looking...
Just got it all buttoned up and now I'm not sure it looks correct. I'll post pics later today and let people weigh in with opinions.
Brake and Speedo Cables
Okay, here's where I'm at with running the lines.
Hand brake cable runs on top of the rear motor mount and speedo goes under mount. I'm open to opinions on whether this configuration is correct.
Saved this image from MUD when installing the motor mounts.
Just keep it away from the exhaust.;)
