i'm hoping he's talking about getting rid of his p.o.s. aa propeller mount on the back of his tcase.
i hate em i hate em i hate em.
you could always see if treeroot has the drawings of his upper mount crossmember to the tranny, but either way, let that tcase hang.
What kind of problems should I watch out for with the propeller?
Thx,
B.
& I added the AA support brace under the adaptor - there is a provision for it. You can kinda see part of it right in the middle of the pic. I haven't had any problems w/ the plate style adaptor & propeller brace on my 40.The twist of the motor eventually loosens the bolts in the AA adaptor. I think the poly bushings on those propeller braces don't give enough, like the rubber motor mounts, so the tcase can twist w/ the motor. I'm runnin the SM420/ AA adaptor/ propeller brace on my& I added the AA support brace under the adaptor - there is a provision for it. You can kinda see part of it right in the middle of the pic. I haven't had any problems w/ the plate style adaptor & propeller brace on my 40.
What issues are folks having with the AA cross member mount? I have one on my stock tcase, and have no issues. Well, that isn't entirely true, i have no issues now that i drilled out the metric bolts, helicoiled with 3/8 corse thread, and secured with grade 5 bolts with locktight and lock washers....Hasn't leaked since.
Just curious.
That's the same way I set mine up,I wish I knew that before It was all done!I did get some nice rubber dampers to mount it to,was hoping that would allow flex without breakage.I've only got four mounts,two frt,two Rr.in a v8 conversion, you've got the front of the powertrain supported and the very rear supported, so everything inbetween in subject to flex and twisting, which causes bolts to loosen up and leak. i used to have to go through my trans/xfer adapter and retighten every six months before i got rid of the propeller and made a transmission mount.
That is a good idea. Did you mount to the tranny, or the adapter (assuming you are running one) between the tcase and tranny. I have the AA 6" adapter, and i think there are some holes on the bottem that i can use to mount to. Just want to know if they are strong enough or if they will twist and loosen like the propeller.
If you have any (and are ok with it) pictures, could you please post?
I think Poser had a post about using studs rather than bolts to secure the propeller mount. It was working OK last I checked.
TreeRoots custom x-member is the cat's ass, though
Rf
