- Joined
- Jul 18, 2003
- Threads
- 21
- Messages
- 64
Having trouble getting my temp gauge to work proper on my 73 fj-40.
Gauge is an H at startup and will not go to C, or goes down slowly.
I removed the connector fron the sender and put it to ground, and the gauge goes to C with the key in the on position.
I tried this on two senders I have from the same year engine. The sender towards the rear of the head with the spade connector.
Do I have a bad sender (s), or am i Missing a ground somewhere.
Motor was not running prior to tearing everything apart, so I have no reference to know if it was working before.
Thanks. Rob.
Thanks. Rob.
how stupid do i feel. maybe i should just shut up and go back into hiding
