Over the last two year a friend a I have rebuilt/modified a ‘73 FJ40 I have owned since ‘95. BTW this is the first time I have posted pics to a web site, hopefully they come out ok.
Neither my friend nor I had ever rebuilt an off road vehicle, it was alot of fun/time/research/beer
/welding. The following modifications have been completed so far...
Frame and Roll Cage modeled in SolidWorks/Cosmos (Eng Software)
10 Point External Roll Cage
Fab Back Half and Front bumper
Racing seats w 4 point seat belts
Richmond Gear - Front and Rear Lockers
4” Skyjack Lift Kit (From Springs)
8k lbs primary front wench and 2k lbs secondary wench (3 mount points under frame)
Fab front shock towers/shocks with +4.5” travel over factory
Front and Rear articulation shackles
20 Gal Poly Gas Tank
Power Steering w/cooler
4 Wheel Disc Brakes
MSD 6 Off-road Ignition, Timing Computer, and Blaster 2 Coil
Front and Rear Differential Breathers
Headers w Cherry Bomb Muffler
Fab Transfer Case w ¼” steel reinforcement bracket (Similar to the SOR bracket)
New side view mirrors and flood lights
5 Gal Air Compressor System
½” Increased Diameter Steel tie rods and steering linkage
15” MT Wheels and 35” Dick Cepek Mud Country tires w/Staun Internal Beadlocks
Boxed the door tops/sides and removed glass
+ Dozens of structural modifications (Anything Not Mentioned Basically Still Toyata Factory Parts)
On a 20Deg Ramp my average RTI for all 4 wheels at 6 PSI was 840
With all the new weight on the vehicle and taller tires, I can barely go 60mph -- down hill! So it is defiantly not worth upgrading the original straight-6 even though it runs well, as it can never have enough power per the modification costs. Therefore, I bought a Chevy 1977 1/2 ton truck and pulled the 305 CI motor/ turbo 350 transmission from it. Why did I want a 305??? Many reasons, but most importantly I won't need the extra 45 CI, it gets much better gas mileage than a 350, I have had better personal experiences with 305s vs 350s, and the Carb/Intake I already have match better to a 305 than a 350. Here are the ‘new’ parts I have...
Chevy 305 CI w 8.5to1 (Compression Check of 150-165 psi on all 8 cylinders)
M/T Aluminum Valve Covers (Chevy Orange power coat)
Edelbrock C3BX Intake (Chevy Orange power coat)
Turbo 350 Trans
Comp Cam Kit --- K12-235-2 Chevy 262-400 Xtreme 4x4
Holley 670 CFM Truck Avenger Electric Carburetor #0-90670
After all the reading/research... I would like to use the turbo 350 trans but I am not sure what is a good/low cost transfer case (before I spend ~$600 for a man-a-fre conversion kit)?
With the steel bracket modifications to the FJ40 transfer case would it hold up?... What actually brakes on the FJ40 transfer case if it is braced properly?
What should I do about the drive shafts; will the stock shafts hold up?
Also, are there any snorkel kits or home snorkel mods web pages for a Snorkel on a Chevy Small Block in a FJ40?
Tks for any Help.
/welding. The following modifications have been completed so far...Frame and Roll Cage modeled in SolidWorks/Cosmos (Eng Software)
4 Wheel Disc Brakes
Turbo 350 Trans
Tks for any Help.
