Hey all,
As requested, here are some pics of my ScanGauge II install.
If you are not familiar, you can research the ScanGauge II here.
http://www.scangauge.com/
I started with this kit from eBay which includes the ScanGauge as well as the BlendMount for mounting above your rearview mirror.
http://cgi.ebay.com/ebaymotors/Scan...008QQitemZ180319141690QQrdZ1QQsspagenameZWDVW
I ran an ethernet cable from the back of the unit and pushed it up along the upper lining and the windshield. I then ran it down the A-piller, making sure to stay away from the airbag systems. Also, if you use cable ties, do not crimp against the washer fluid hose to the rear. To remove the A-piller cover, take off the 2 caps on the handle and then remove the bolts. Then pop the cover off.
I used the female-female junction and placed it in the lower A-piller next to the front right speaker where the windshield meets with the dash.
Then, starting from the ODB-II connector, route the ODB-II cable up and around the engine and gas talk release levers. If you pull the rubber molding back a bit, you can pop off that side panel where the door rests. Route the cable up and connect it to the ethernet splitter.
I had to do some bending of the BlendMount to get the unit to sit right against the rearview mirror. My problem was that I needed to bend the mirror back far enough that the mirror would be at the correct angle. Being 6" 1", this needs to be almost flush with the windshield, thus not allowing much room for the mount. The BlendMount comes with varying length posts, and I had to use the shortest one so it would allow the rearview mirror's post to lift up high.
Anyways, I bent it and it's up there and looks good.
If you have any questions, you can ask. I suck at writing this stuff down and I'm tired.
PS. I have not played around with the XGauge commands, which I need to find time to do.
I set the color to Blue HIGH for the pics, but I usually leave it on Red LOW so it's not so bright.
