- Joined
- May 24, 2009
- Threads
- 3
- Messages
- 8
First off. I have been a long time lurker and would like to say that this is a great forum.
Problem: My 2000 LC with 147,000 miles has just started running rough. Ran a scan and got the code for a bad OS. Due to work, I did not immediately replace the OS and continued to drive it for a couple of weeks. During this time, the CE light and the VSC light came on and it started running very rough.
I changed the OS and disconnected the battery to clear the CE light. This worked for about 5 minutes and then the CE and VSC lights came back on. I have just ran another scan and the OS code does not come up, but misfiring codes on 5 of the cylinders shows up 300, 302,303, 304, 306.
Where should I start? Replace the plugs or assume a bad coil?
TIA.
TIA.
