SM465 top plate install
In order to remove the shift cover, you have to have the shifter cane partially engaging reverse. So in order to install it, it would be the same.....
If the reverse gear (low in the case on its own shaft) slid once the cover was off, you may have to move it by hand. You want it to have about 1/2 tooth engagement with the reverse-driven gear on the mainshaft which will allow the right amount of space for the shift fork. It can be a booger, but when you have done it as many times as I had to.... :bang:
