hi, im james,
i was trying to sell this HJ45, but now am doing a 2H conversion
atm i only have a recond 2H, bell housing, transfer, tailshafts, front and rear diffs with disc setup inc calipers, clutch is missing, as is disc brake master cylinder. i dont know if it has the steering components, p/s (im picking it up next weekend).
my H motor is kerfxxxied, blows copious amounts of smoke, prewarmer is non existent, and that turn over takes for ever.
leaks oil from block, and the tray needs to be cut from chassis and re-aligned, as its an inch to the right , right side is an inch closer to the cab, and its not level 8\. tray is not much really. hence why im doin the motor swap
now id love to do the 2H with a 5 speed and i know that means rear cross member mount etc. with this motor id love the disc brake conversion to, I DO NOT have a 5 speed
, oh does anyone know if the 4 speed box to transfer changes when its 5 speed box to transfer? as in, do i have to get a new transfer to match the 5 speed box?
other than that, ill post photos of the car before , during and after, and of the gear.
at first ill be just dropping the motor in as is - hopefully, and then ill get round to the rest, prolly after i find a 5spd
