I've been having this issue for a couple of months now and haven't had much luck in tracking down the issue. What is happening is that once the engine (96 4Runner V6) has warmed up (isn't overheating or anything) and I shut off the engine, after about 15 minutes or so it is impossible to get it started again without using some starting fluid. If the engine is shut off and I try to start it again within about 5 minutes everything starts up fine, but past the 5 mintues it get harder and harder to start again. Between 5 and 15 minutes I can sometimes get it started if I hit the gas at just the right time, but after that I have to wait for about 50 minutes before I can get it started again.
When I do get it started, either with starting fluid or waiting, it runs perfectly for as long as I want to run it.
I've attached my computer to the OBD and monitored/logged the values that the sensors are spitting out and they seem to be the same as on vehicles that are running with no problems. That includes things like the coolant and intake air temps, O2 sensors and others. I've also checked the resistances on a number of the sensors and have found them to be in the right ranges as specified by the Toyota docs from TIS. I've also cleaned the MAF sensor with a little electronics cleaner. I've changed out the plugs and wires too (not Toyota parts, but the problem was happening before and after this change so figure that isn't it). Also just replaced the fuel filter since it was cheep.
I'm not really sure what sensors are used at startup (open-loop in the computer), but everything that I can test electronics wise seems to be ok. I was wondering if maybe it could be a problem similar to vapor lock? I haven't really been able to test the fuel pressure during the times that it won't start (fuel pressure regulator?) and I haven't been able to have the injectors tested yet.
The real strange thing is that once I get it started it runs without any problems at all. No check engine light or anything. Idles nicely, good power at all speeds, no stumbling.
I did take it to the stealership, but that was a total waste of time as they recommended that I change the plugs/wires (already done) and fix the super small crack in the airbox (not the problem) which I could test out with duct tape. $90 down the drain.
Anyway, any ideas/suggestions would be greatly appreciated. Also, does anyone know what sensors are involved during startup (coolant, intake, egr, etc.)? I get this bad feeling I'm going to have to start replacing parts to get this fixed and I really don't want to have to start replacing injectors and sensors that don't need to be replaced.
Thanks ahead of time for any help! I'd love to get this fixed and post all the steps/fixes since I've seen issues like this posted before and not many have any resolutions.
