29Jun2005 (UTC +8)
Can this service specification make it into the FAQ?
I compiled this because I'm consolidating my LC maintenance info and it was easier to reference now. If there are any corrections, please feel free to tell me about it!
* I got this info from geniune Toyota publications & service manuals. Though I have the Haynes, Max Ellery, Gregpry's, and other books, I didn't consult them for fear of getting erroneous info.
Vehicle: Toyota Land Cruiser (FJ-80)
Engine model: 3FE, 4.0L gas-engine
Fuel type: 91 RON unleaded, 95L
Engine oil: API SG, 7.8L (with oil filter change)
Coolant: Ethylene-glycol based, 19.5L (with fr/rr heaters)
Transmission, automatic: ATF Dexron-II, 15.4L (dry fill) or 6L (drain & refill)
Transfer case, HF2A: API GL-4 or GL-5, SAE 75w90, 1.3L
Differential, front: API GL-5 hypoid gear oil, SAE 80w90, 2.8L
Differential, rear: API GL-5 hypoid gear oil, SAE 80w90, 2.8L
Power steering: ATF Dexron-II, 0.75L (total) or 0.51L (tank only)
Propeller shaft: Lithium-base multi-purpose, NLGI-2
Wheel bearing grease: Lithium-base multi-purpose, NLGI-2
Brake fluid: SAE J1703 or FMVSS 116 DOT-3
Vehicle: Toyota Land Cruiser (FZJ-80)
Engine model: 1FZ-F (carburated) or 1FZ-FE (EFI), 4.5L inline-6 cylinder gas-engine
Fuel type: 91 RON unleaded, 95L (+50L with sub-tank)
Engine oil, 1FZ-F: API SG, 7.6L (with oil filter change)
Engine oil, 1FZ-FE: API SH, 7.4L (with oil filter change)
Coolant: Ethylene-glycol based, 13.4L (with fr/rr heaters)
Transmission, automatic (A343F): ATF Dexron-II, 1.9L (drain & refill)
Transfer case, HF2AV: API GL-3 or GL-4 or GL-5, SAE 75w90, 1.7L
Differential, rear: API GL-5 hypoid gear oil, SAE 80w90, 3.25L (use LSD oil for LSDs)
Steering knuckle: Molybdenum-disulfide lithium-base, NLGI-2
Vehicle: Toyota Land Cruiser (HZJ-80)
Engine model: 1HZ, 4.2L inline-6 cylinder diesel-engine
Fuel type: 50 cetane number, 95L (+50L with sub-tank)
Engine oil: API CC or CD, 9.3L (with oil filter change)
Coolant: Ethylene-glycol based, 11.9L (with fr/rr heaters)
Transmission, manual: API GL-4 or GL-5, SAE 75w90, 2.7L
Transmission, automatic: ATF Dexron-II, 15L (dry fill) or 6L (drain & refill)
Transfer case, HF2A and HF1A: API GL-4 or GL-5, SAE 75w90, 1.3L
Transfer case, HF2AV: API GL-4 or GL-5, SAE 75w90, 1.7L
Power take-off: API GL-4 or GL-5, SAE 75w90, 0.1L
Winch, mechanical (2000 kg-f): API GL-4, SAE 90, 0.5L
Winch, electrical (1000 kg-f): ATF type F, 2L
Vehicle: Toyota Land Cruiser (HDJ-80)
Engine model: 1HD-T (12 valve) or 1HD-FT (24-valve), 4.2L inline-6 cylinder turbo diesel-engine
Fuel type: 48 cetane number, 95L (+50L with sub-tank)
Engine oil, 1HD-T: API CD, 9.3L (with oil filter change)
Engine oil, 1HD-FT: API CD, 9.7L (with oil filter change)
Coolant, 1HD-T: Ethylene-glycol based, 11.9L (with fr/rr heaters)
Coolant, 1HD-FT: Ethylene-glycol based, 12L (with fr/rr heaters)
Transmission, manual (H155F): API GL-4 or GL-5, SAE 75w90, 2.7L
Power steering: ATF Dexron-II, 0.8L
