I have received many emails and PMs since I posted that I had to suspend harness building operations. It appears a number of you would like to take a crack at building one of these and would like information about where to get components. I have not had time to respond to all of you. I apologize for that. I have been working 60 to 75 hour weeks and I haven't even had a chance to read MUD. It is looking like things will calm down at work after Christmas, so I'm hoping I can get back into cranking out some more harnesses then.
I don't have time to do a build thread, but if you have some wiring experience, or just want to give it a go, you can get the parts to build one of these from the following sources:
Waytek Wire--You can buy the Bussmann RTMR relay panel, terminals, crimper, seals, plugs, mounting brackets, fuses and relays (I like the Song Chuan brand relays). The relays are 35 amp micro relays, and the fuses are called mini fuses. Don't order over the web, call them up and ask questions, they will help you get the stuff that works together. Some things are hard to find on their website.
Genuine Dealz--You can get wire, heatshrink and braided cable from them.
Spectro Wire and Cable--These guys sell wire at the best price I could find.
McMaster-Carr--You can buy uninsulated butt splice connectors, ring terminals, crimper and heat shrink from McMaster
That should get you all the parts you need. My old Merchandise Storefront thread
https://forum.ih8mud.com/merchandis...light-wire-harness-fj60-fj62.html#post5197952
has lots of pics and info along with the schematics in post #2. So, if you want to give it a go, build yourself a harness and post up a build thread. If I get time to start building these again, I'll start a new thread. I have a wait list still that I haven't even dented, and they will get first crack.
