FJ40 '82 Diesel Rebuild in progress
Surabaya, Indonesia
www.x5model.blogspot.com
Dear All,
My name is Andhika from Indonesia. I'd like to share the progress of rebuilding my FJ40 '82 Diesel. It contains some pictures taken during restoration. For more complete documentation please go to TOYOTA FJ40 '82 Diesel
Originally was '82 Hard Top version in maroon red (Muleta Red T1454). After 15 years driving pleasure, I will convert this rig into Soft Top Version in desert color scheme. Some goals we plan:
-New look, fresh from factory, military jeep's like.....as possible
-Apply new design for lighting system using LED, especially to replace the bad design of tail-stop lamp.
-Minimum budget........ Is this possible?
It is hard to find but we try to restore the missing parts using genuine one as possible, make some minor modification and adding new better parts. I hope this experience will useful to someone who want to build this rig. Feels free to comment.
Thanks to Mr. Diran that successfully 'break' this car into pieces and put them together again.
Nice work!
Rear lamp unit
Dear all,
Thanks for the support.
Is this good or bad idea to put new design of LED rear lamp unit? Is there any experience using LED before?
:idea:We found the problem of this important part is malfunction by dirt and rust. I'm in progress of making this waterproof lamp unit.
The lens, reflector and back cover already done. Now I'm waiting for PCB and LEDs, this unit should be finished in a few days.
I know this is not OEM. If this experiment resulting a better lamp, I'd like to use it.
See more at this link
LED lights do perform better than the old filament-type (generally speaking ...in all applications except for the headlights themselves).
They:
  • are more rugged
  • are more reliable
  • are longer-lasting
  • use less current (for the same brightness)
But an unfortunate side-effect of the low current-draw is that an old-style blinker relay may malfunctiuon when used with LED turn-signal bulbs.
Another negative is that they create very little heat .... and I like the way conventional filament bulbs tend to dry out their enclosures (with the heat they produce). .... But this comment only applies to LED bulbs and not the "sealed-unit-type LED lights" you're considering.
Go for it.
:beer:
Andhikae,
Selamat Datang MUD! It looks like you have a pretty good build in progress. I think the military look for your '40 will turn out very nice. Have you considered painting your wheels black? What other modifications do you have planned?
Keep posting your progress pictures!
Vacuum parts LED lamp
The result of vacuum forming........:)
A simpler way might be to use these. Mine work great and havnt had any problems. They even have the flasher youll need. Super Bright LEDs – 12 Volt LED Car Bulbs I like your idea though.
Thanks for the link Ron, the site informs many types LED available. The LED working in the range of 2.8-3.6 volts.
My circuit design is a series of 4 LED's for 13.5 volts, each LED will get 3.38 volts. Also inform that a load resistor required for old-style blinker relay (6 ohm, 25 W)
Andhikae,
Hi Kotekaman, glad to see you. Finally you've found the specific nickname.....:D
I just do some minor modification, it is enough for me to make this big daddy run again. In my opinion military car should:
- Using lamp cover (black out light). No, I need bright light for safety driving.
- Camouflage color. It is not good for this car.
- Jerrycan, big antenna, ammo box etc. I will think about it. My fund resources seems depleted.......:crybaby:
- Tactical symbol and decals. This is the best we can do, unfortunately this vehicle has no battle record in history.
I think I will fail for military's look.
It appears a common problem of being a '40 owner is being depleted of funds, including me!
I think you got the look for your '40 nailed:
...except yours is nicer, it's a Toyota, not a Rover.
Also remember, in Papua, never judge a man by the size of his koteka :cheers:
