What is zero rust like compared to por15? JCwhitney has zero rust on sale. does auto paint go on top of zero rust? How is it for those of you who have used it?
Ethan said:I got 2 gal of zero rust black from jcwhitney (never thought I would really order from them) It was half off so I went for the 2 gal. should be enough for the fj40's frame and under the body.What is a good recomendation for getting a gloss top coat? Yeah I know some of you are wondering why gloss. I want a hard gloss finish so that its easy to clean. flat and simi gloss collect dust. I dont mind dust as long as I can at least clean it off every so many years. So what would be a good hard gloss finish? I had seen that there is a hard nose tan por15. what is this tan like. I want to paint my cruiser tan. Is it close to dune beige? Any one use this? (I would use the tan for the body) OR does it sound like i am retarded with the whole gloss thing due to the fact that most of the stuff Im putting it on is under the hood or on the frame.
wesintl said:You can seal the zero rust with urathane to prevent uv fading etc. I sand blasted a m416, zero oxide red then 2 coats of tan and 2 coats of urathane. I recently did the rear frame and axle on the bj.
Yes I used crystal clear myself but on top of my rattle can paint jobwesintl said:Actually I think I probaby used the zero rust acrylic clear coat. I can't remember as it was a while ago and I also painted some softtop bows around the same time. If you let it dry it needs a week to fully cure before you apply the clear but you can spray it within a couple hours of the applying ZR. I think I let mine dry about 1-2 hours.
http://www.zero-rust.com/crystal-coat.html
