Does the 1FZ-FE motor require any amount of zinc or ZDDP?
I was thinking that it was the ZDDP/zinc in the RotellaT and T6 oils that was contaminating the cat's and MAYBE the O2's via oil consumption. I sent an email to Shell and got a reply:
Dear Sir,
If you are using oil between oil changes (consumption), then you can shorten the life of a catalytic converter which is the result of the ZDDP additive contaminating the catalyst. It is for this reason that we do not recommend using Rotella oils in gasoline engines with catalytic converters.
There is no way I am aware of to remove the conatmination once it is attached to the catalyst.
Regards,
Shell Technical
I have recommended the use of Rotella T and T6 syn 5w40 in the past. I have been using it in my 80 for not quite 200,000 miles. My cats need to be replaced (do to emissions testing) and I have gone through several O2's (which may or may not been a result of ZDDP oil contamination) that will need to be replaced to pass emissions test. (I am running with out O2's at this time)
I am posting this to:
1) Ask if ZDDP is required or recommended in the oil of the 1FZFE?
2) Let others know they MAY be damaging their CATS and or O2's (If they even care) with use of oils that have ZDDP in them if they have oil consumption while using oil containing ZDDP .
3) Find out if the use of ZDDP, to prolong engine life, is worth the cost of damaged smog parts?
Dear Sir,
Regards,
Shell Technical
