- Location
- United States
Jan. 1976 Toyota FJ40 Landcruiser
$28,000
As of February 4, 2020, new pistons +.030 (ITM), rings, rod bearings +.020, cylinders honed, rebuilt cylinder head and gaskets, water pump and thermostat gaskets, and exhaust gaskets.
Odometer reading at time of overhaul (32032) actual mileage unknown. Less than 1,000 miles on Dick Cepek 33 x 12.5 x 15 tires. Break pads and shoes recently replaced.
90’s Jeep Wrangler tilt steering column and seats (recently reupholstered)
All dash pads recently replaced (Fj40.com), headliner recently replaced. Rear ambulance door latch replaced. Period correct center console.
New silicone vacuum lines. All smog equipment installed.
Power steering, power assisted front disc brakes.
Heavy duty frame mount swing away rear tire carrier. Heavy duty front bumper with 9500# winch.
Front windshield recently replaced. All gauges, and controls working. Auxiliary fuse box and toggles control USB, fuel solenoid switch (anti-theft) and front mounted LED bar.
Spring Over Axle lift,
Rancho 9500 shocks. Rebuilt 2bbl Aisin Carburetor, double cardamom rear drive shaft. Double cardan rear drive shaft, both front and rear axles rebuilt
Extras: Warrior tube doors, Bimini top. Rear tail gate.
$28,000
