A few months back my A6 A/C compressor died after 30 years as an air compressor. Since I’d overheated to an had it lock up a few times I decided to replace it with a York compressor.
After searching around I found a wrecker that said they had a York pump. Long story short it was a Tecumseh cast iron pump… I decided it’d work and should be bulletproof. I’ve been making brackets to mount it on my 350 SBC out of 1/2” plate and I’m not worried about a couple extra pounds.
Until I stumbled across a free York 209. Down side is it’s a bit less than 9 cubic inches… upside is the pulley is a lot smaller so it’ll probably turn 20-30% faster. It’s probably also 10-15 pounds lighter. On a 4700 rig, 10 pounds heavier isn’t much to worry about, but I’ve read that they run hotter.
Which way would you go? Lighter, faster spinning, smaller displacement aluminum pump or Heavier, slower spinning, cast iron pump?
I’m in favour of bulletproof… the A6 failed at a bad time.
