yet, another project to do
in the garage
got these from jeepnmatt on pirate
diff rings about $70. for two
something to use to build diff protection...
Once tack welded did you bolt or brace your link plates in casue of pulling or warpage due to welding??
DHONDAGOD said:
this is what i did...
freshly welded...
after grinding.... the fill plug was moved to the top... 1/4" steel plate, one 250 amp mig and a BIG hammer...
btw, this is my rear axle.. :D
chris:cool:
Looks Good Jim-
It will be fun to see what you do with them!
Rezarf <><
those are all great ideas, but none will work w/removable cover
any ideas for sill being able to remove it?
jim, how will these work with the bubbled out sheetmetal on the stock covers?
:confused: are you talk'n bout the bubble for the ring gear?
in the first pic, the diff ring has the notches cut for a perfect fit on the cover.
or are you talk'n bout the bubbles around the edge of the cover?
