Yet another new issue with the 40....
Discussion in 'SC- Upstate Cruisers' started by ClemsonCruiser, Aug 10, 2005.
  1. ClemsonCruiser
    ClemsonCruiser
    8,871
    Media:
    1
    Albums:
    1
    1,812
    Feb 17, 2004
    Clemson, South Carolina
    I swear my poor 40 is trying hard not to go to Tellico this weekend. After batteling carb. and fuel delievery demons for the better part of week now I finally have gotten them worked out enough so that the 40 will hit 60mph, which should be sufficent to get me to Tellico.
    and what do I notice after test driving around for a while this morning......... I am leaking axle/gear oil from the passenger side, it was slung all over the inside of my tire............:mad: so I might have to replace the seal in there too, I am going to try to see how bad it is first. Just in case though does any one have any axle seals??? I don't think I could order one and have it arrive on time and plus I have 9 bucks to my name..........
    Oh the fun continues, I am just ready for friday!!!!!!!!!!!!! :cheers:
  2. Trollhole
    Trollhole THC Supporting Vendor Moderator
    20,939
    Media:
    79
    Albums:
    4
    3,018
    Mar 6, 2005
    Mauldin, SC
    My inventory
    #27
    #30
    #25
    all new
    1 slightly used inner axle seal. 1000 miles on it. I think it will still work
    [​IMG]
  3. CruisinTiger
    CruisinTiger
    2,973
    146
    Oct 22, 2004
    Clemson, SC
    hittin that hole really f'd you bad man
  4. Trollhole
    20,939
    Media:
    79
    Albums:
    4
    3,018
    Mar 6, 2005
    Mauldin, SC
    lets see a picture. Is it really comming out of the hub or is it comming out of the knuckle where the felt is?
  5. ClemsonCruiser
    ClemsonCruiser
    8,871
    Media:
    1
    Albums:
    1
    1,812
    Feb 17, 2004
    well I just finished skinning one of the tube fenders one to go them I will take a pic
    and doesn't appear to be coming out where the felt is, rather it is being slung out via the slots in the rotor...........
  6. Capt. Jim
    Capt. Jim
    2,215
    3,030
    May 1, 2005
    West Palm Beach, Florida
    JP,
    If you took a hard hit on that wheel, as mentioned above, you may have cracked something. Perhaps the hub if it's coming out from the rotor vents. :confused:
  7. ClemsonCruiser
    ClemsonCruiser
    8,871
    Media:
    1
    Albums:
    1
    1,812
    Feb 17, 2004
    well it was actually the other hub/side that took the direct hit, so I am hoping it is just a seal......
  8. Trollhole
    20,939
    Media:
    79
    Albums:
    4
    3,018
    Mar 6, 2005
    Mauldin, SC
    What with you and those rotor seals? This is #two for you. Quick fix would be to pull the rotor and replace the bearing seal. You would still have to get the inner axle seal sometime but at least this would keep all the goopy grease/gearoil from comming out. Might take 15 min. For a patch for this weekend.
  9. Trollhole
    20,939
    Media:
    79
    Albums:
    4
    3,018
    Mar 6, 2005
    Mauldin, SC
    The ironic thing is it was a hole I made when pulling him out of the first ditch he wedged himself in.
  10. ClemsonCruiser
    ClemsonCruiser
    8,871
    Media:
    1
    Albums:
    1
    1,812
    Feb 17, 2004
    hmmmmmmmm...... in that case marshall you owe me a few hundred for the new springs and for my emotional tramau, luckly we have it all on film
  11. Hard40
    Hard40
    721
    Apr 17, 2005
    Seals Aplenty
    JP, May have what you need. I can also pull a hub off the 79 in my shop yard which will have a seal and bearings included. Let me know. There yours if you can use. 313-9407 Cell. 836-6641 Home.
  12. ClemsonCruiser
    ClemsonCruiser
    8,871
    Media:
    1
    Albums:
    1
    1,812
    Feb 17, 2004
    Alan, I appreciate it. I am going to take a look at the hub this morning. I took me a lot longer than expected to weld up the fenders and aprons........ I will let you know.
  13. Hard40
    Hard40
    721
    Apr 17, 2005
    Your 40 is going to Tellico even if we have to jack it up and drive another under it! ( Yogi Berra) If it weren't for bad luck you wouldn't have any!
  14. ClemsonCruiser
    ClemsonCruiser
    8,871
    Media:
    1
    Albums:
    1
    1,812
    Feb 17, 2004
    Well, I loned my GF my 62 today and forgot to get my jack out, so I haven't gotten to check out the wheel yet. That will be first thing in the morning, it shouldn't be a hard fix though :)
    My 40 will be there for sure, I just hope it does so under its own power.
  15. Gundy
    Gundy
    3,191
    10
    Jan 2, 2003
    Dweller on the Threshold
    I'm
    hoping we all make it to Walhalla.
    Tough run of luck JP. Good luck
    tomorrow morning. I hope it's minor repairs.
