Green Lantern
Have Truck, Will Travel
I ran a search and this banana peel mechanic is still confused...
I apologize if this is simple.
My 1981 BJ42 has a 3B and everything is stock. The EDIC relay clicks like a chipmonk when it starts. No clicks, no start. Once I get it started the engine continues to run after I switch the ignition key off. I can stop the engine by manually pushing the EDIC motor arm to STOP.
I cleaned the plugs at the EDIC relay and the EDIC motor. I checked the ground wire from the battery, it's good. The relay is firmly grounded to the glovebox. The EDIC motor appears to groound to the motor block. I checked and cleaned the Engine fuse. I haven't found the oil pressure switch, but since it runs, I think it must be working.
I cleaned the contacts on the ignition switch too. The glow system appears to work normally. Next, I replaced the EDIC relay with a new one. Same symptoms, same problem. :-(
I'm hoping my Northern dieselhead friends can suggest something before I start checking individual electrical lines.
BTW, I saw Brown Bears post about which wires do what at the EDIC relay. Unfortunately, my wires have different colors. The always hot wire on mine is white/blue. Two wires are hot with the ignition on and all wires show ground (except white/blue) with the ignition off. I haven't tried unplugging the relay with the engine on yet cause I was afraid it would mess up the relay. HTH
Thanks in advance.
Happy Trails! N
Thanks in advance.
Happy Trails! N
