Yet another converter question
Calgary, AB.
I know this topic has been beaten to death, and I have done numerous searches, but I am still not positive what I need for a 24v - 12v converter. In my 87 BJ 73, I need to run my new stereo, which includes a sub box and a 300w 2 channel amp. I also would like to run my CB radio. I am looking at the ICT 20 amp converter from Huttons, here in Calgary. So, bottom line - new cd player, 300w amp, and CB radio. What do I need for amps in a converter? Please help!! :)
Once you add an amp to the equation you should go to 30amp. The load that an amp creates is going to be a large draw. Look at a capacitor for your amp and a charge balancer for yur batts. My view is best to spend a little more up front than deal with two dead batts when it is least convenient[been there]. Here is a good place to do a little reading re 24v issues.
http://www.newcruiser.ca/index.php?CID=2G
Natty, what you need to find out from a radio shop is how much amp max your radio system will pull.
I've been using a 16 amp, for fog lights, CB, radio, and lighting in my BJ for a very long time without issue with a 16 amp converter. Unless you radio amp is going to pull alot i'd guess you will be fine. But if you do not want to take chances call a radio guy, tell him what you and what amp max you will draw.
An Amplifier wanting to put out 300W at around 13V will require roughly 23A according to Ohm's Law.
For your type of demand, I would highly recommend the Solar Converter as discussed in several threads here and linked in the FAQ section. The setup as I had last discussed it will allow you to draw large transient loads from your low-side battery and the Solar Converter will continuously equalize them to keep them happy. The switch also allows you to go into strict step-down conversion without interrupting current to your accessories, should you need to do that (like leaving your truck for extended periods, especially in cold weather).
I wouldn't go too much more in terms of accessories and load demands as your diesel alternator does not put out very much current at all.
Good luck.
