I bought this at Costco, around a hundred bucks. I was thinking of more sophisticated installations, but have found that this is working for me, so I'm just living with it as is, and thought I'd share. I installed the camera in the standard way, bringing the wire to the Driver's side taillight through hole I drilled (look for the white silicone for where I put the hole.)
Inside I didn't want it very prominent - where I might feel like I was inviting someone to break in to grab it - so I went with simply pushing it into some "Loctite" brand mounting putty down in front of the ash tray. The Locktite putty is about two bucks, allows me to just grab it and go if I want, and otherwise always holds it in place. But is not very scenic. (I have a big wad of it under the screen and another along the top as you can see.)
As far as the camera - it turns on very quick, the definition is good. The guide lines you can select to have displayed were too wide for my tastes, I prefer to have them off. It helps to insure someone/thing is not immediately behind me when I back up, otherwise, I don't refer to it.
Worth the hundred bucks.
Gil
Ventura
Gil
Ventura
