xfer case rebuild kit
Colorado
I'm going to delve into the world of renovating my 78 fj-40, and thought a rebuild on the tranny and xfer case would be a smart place to start, who makes the most complete kit to rebuild the xfer case, also i can't get crap for info using the search option any tips on that also, TIA, Brad.
i also used man-a-fre
i think when i rebuild mine i will just get the Marlin Crawler 4.7 Low Range Gears, the kit comes with new seals and bearings and stuff.. and its like $450.. so for $350 more you can kill two birds with one stone and have a nice Crawl Ratio!!
MAF has a good kit and also had the necessary stuff to match the three speed up to the 4spd tranny. Maybe I'm wrong but I think the only way to use the Marlin gears is to install them in the toybox. I checked their website and it seems a little misleading the way it's written that they fit the 40 but I know the gears in the past were so big that you either had to clearance the inside of your existing case or buy the billet one from Warden's( is that still available from anyone else?). The 4.7's fit only the p/u xfer case as far as I know.
[quote author=isotel link=board=1;threadid=9780;start=msg86343#msg86343 date=1073513805]
[/quote]
Are you thinking the ToyBox? There are not 4.7 gears that will ever fit into the stock t-case, mini trucks yes, but cruisers nope. Hence the reason for the Orion, Rockbox, Toybox... :D
Hmmm... maybe so, but their site seems to suggest that it works fine,,
Quote from them ...
Our 4.70:1 gear set replaces the stock gears in Toyota gear driven transfercases. This means that any vehicle with this transfer case can use our gears! We have applications available from 1979 - 1995 Toyota Pickups and 4Runners, 1996+ v6 T100's 1996+ V6 Tacomas, 1996+ V6 4Runners and now with our new ToyBox, we can now run these gears in many Jeeps, chevys, Dodges, Fords. It's also fits most FJ40-62 4-speed applications.
http://www.marlincrawler.com/gearsets.html
it looks to me that they are a direct replacment, but maybe its just wishfull thinking
ok, called, talked to marlin himself,.. yall are right im wrong
the web site makes it seem like those 4.7 gears will work.. wishfull thinking i guess..
