Asking Price: $8,000 OBO
Thing will Wheel. It truly works, dependable, reliable, when the tires are aired up I have had it at 65 no problem (it was just chilly with no windshield). Heat and AC work, just a smashed cab is all. I probably have, with purchase price $22K - $23K in it. You can see the list of Parts below, no expense spared, 14K just in the parts. I love it but ready to move on.
Has regular doors and tube doors, will obviously include both. Thing has tackled some of the hardest terrain in Clayton including Green Momba and Green Momba's Extension. Super Low Crawl Ratio.
Put together a list of just the parts on it:
Drivetrain
FROR Tacoma Crossmember and Skidplate Combo $349.00 Front Range Off-Road Fabrication
Marlin Crawler Built Tacoma Double Transfer Case Setup, 4.7:1 $1,995.00 Dual Case Unit (MC09-T360) | Marlin Crawler, Inc.
FROR Tacoma T-Case Twin Sticks $189.00 Front Range Off-Road Fabrication
Axles
Tacoma Custom Width Diamond Axle Housing $900.00 Diamond Axles - Front/Steering Axles
Custom Length Longfield inner axles $330.00 CUSTOM LENGTH 30 SPLINE TOYOTA AXLE SHAFTS - Longfield Super Axles
Longfield Birfields $430.00 27 SPLINE BIRFIELD - Longfield Super Axles
Tacoma Brake Mounting Kit $99.00 Front Range Off-Road Fabrication
Front Toyota 8" V6 3rd With 5.29 Gears, Detroit Locker and Solid Pinion Spacer $1,124.00 Toyota V6 8''- Pickup, 4runner,FJ Criuser
Rear Tacoma Non ELD/ T100/ Tundra 3rd With Detroit Locker, 5.29 Gears and Solid Pinion Spacer $1,235.00 Tacoma Non ELD/ T100/ Tundra 3rd
Steering
FROR Full Crossover Steering Kit $399.00 Front Range Off-Road Fabrication
All Pro Rebuilt IFS Steering Box $399.00 https://www.allprooffroad.com/pickupsteering/246
Suspension
FROR Tacoma Solid Axle Swap Kit $199.00 Front Range Off-Road Fabrication
Diamond Spring Perches - $40/pr $40.00 Diamond Axles - Parts
Diamond U-Bolt Flip Kit - $69 per axle $69.00 Diamond Axles - Parts
All Pro 5" Front Long Travel Leaf Springs $269.00 https://www.allprooffroad.com/pickupsuspension/pickupleafsprings
Front Bilstein 14" 5125 Shocks $158.00 https://www.allprooffroad.com/pickupsuspension/pickupshocks/301
Trail Gear Universal Shock Hoop Kit $52.00 Toyota, Suzuki Samurai, and Jeep Off Road Parts
Tacoma Steering Box Mount & Frame Plate Kit $149.00 Front Range Off-Road Fabrication
Custom Rear Alcan Leaf Springs for pre 97 Tacoma $349.00 https://www.allprooffroad.com/9504tacomarearsuspension/9504leafsprings Don't remember price so going with All Pro lesser springs for price comparison
Rear 5125 - 12" for Lifted Applications (BE5-6249-H5) $158.00 https://www.allprooffroad.com/9504tacomarearsuspension/9504rearshocks/301
All Pro Rear U-Bolt Flip Kits $49.00 https://www.allprooffroad.com/9504tacomarearsuspension/9504uboltflipkit
All Pro Short Shock Mounts $29.00 https://www.allprooffroad.com/9504tacomarearsuspension/9504shockmounts
Armor
Rocktek Custom Front Bumper $499.00 http://www.rocktekcustomz.com/
Rocktek Custom Sliders $359.00 http://www.rocktekcustomz.com/
4x4Inovations Tube Doors - 95.5-04 Tacoma Tube Doors $215.00 4x Innovations: 95.5-04 Tacoma Tube Doors
Tube Bed and Roll Bar Custom $500.00 Custom Made
Wheels and Tires
Trail Worth Fab 12 bolt Double Beadlocks, Powdercoated Hammer Black with Pressed Centers, 6x5.5 bolt pattern and PVC Inserts. Full Rock Rings $1,219.80 $249 12 Bolt Hummer Wheel Special
Pitbull Rocker Radial Tire 37x12.5 R16.5 $1,559.80 Pitbull Rocker Radial Tire 37x12.5 R116.5
Accessories
Superwinch 8500lb Winch with Synthetic Winch Line $449.99 Superwinch 12 Volt DC Truck Winch 8500-Lb. Capacity, LP8500, Model# 1585202 | DC Powered Winches | Northern Tool + Equipment
IPF Lights $99.00 http://www.trdparts4u.com/scripts/prodList.asp?idCategory=21
Modifications Total $13,871.59
Drivetrain
Axles
Steering
Suspension
Armor
Wheels and Tires
Accessories
